I have a 2001 Mitsubishi Diamante LS 66,000 Miles 3.5L V6 MPI DOCH 24V. There is an antifreeze odor when you turn on the a/c even tho the car isn't loosing antifreeze, also it won't blow air out the center vents or up to defrost the windows and it won't defrost the window whether you put it on heat or cold (I don't know if this is just because it doen't seem to blow out the defrost vents or if that is part of the symptoms). the air seems cold that is coming out the side vents, but with it not working with the other vents it is hard to tell. I hope you can help me, let me know if there is any other info you need.
Thanks,
Sally
Thanks,
Sally
Apr 12, 2007 at 4:01 AM
