2000 Other Mitsubishi Models idling
2000 MITSUBISHI
90,000 MILES • 4 CYL • FWD • MANUAL
TOP BOSS
my car idles up and down while its parked and running and when i stop at a red light.the engine runs up and down 2 seconds apart
Apr 18, 2008 at 12:55 PM
BLACKOP555
  • 10,386 POSTS
sounds like you may have a slight vaccum leak, with vehicle idling spray around the manifold and throttle body, and vaccum lines with carb cleaner, if idle changes you have found a leak.
also clean out the throttle body, and check the PCV valve
Apr 19, 2008 at 2:47 AM
