2000 Other Mitsubishi Models Fan won't come on.
2000 MITSUBISHI
GRAFEK
Air Conditioning problem
2000 Other Mitsubishi Models 4 cyl Two Wheel Drive Automatic
Hi, fan on my Mirage stopped coming on for either AC or Heat settings. Possible fuse or relay? The panels have AC and Fan symbols on them. Fuses all look good, not sure how to tell if relays are bad. Would you suggest replacing relays? AC, Fan, or both?
Apr 25, 2008 at 12:15 PM
LEGITIMATE007
  • 5,121 POSTS
sounds like a relay. find the relay and take an ohm meter and test for resistance
Apr 25, 2008 at 3:04 PM
