2000 Other Mitsubishi Models COLD hesitation,stumble
2000 MITSUBISHI
150,000 MILES • 4 CYL • FWD • MANUAL
FRANKMIRAGEMAN
  • 10 POSTS
mitsubishi mirage 1.5l california emission 5 speed, minimal problem noticed/started at 60000miles and got progressively worse. at startup from fully cooled (8hrs+ off), car starts fine with key and idles, BARELY touch the gas in 1st to get on the road and it stumbles, it will have just enough power to roll the car but it won't stall. release the gas and it will idle again, chugging along the road at idle speed. as soon as there's a load on the engine, it will stumble without power to accelerate the car. give it a minute and it will work ok, but have some stumbling on acceleration. after it fully warms up it is fine. this car never had an intake air control unit thing. no active or pending trouble codes. I have a big clue I think with the following: I live on a hill and can roll a half mile without turning on the car in the morning. I put the key to "on" and then coast 1/2 mile before putting it in gear and pop starting it while rolling about 30-40mph in 4th or 5th gear. The engine will not work, specifically, when I touch the gas pedal I feel major stumbling (no acceleration at all) no change even if I floor it, and if I step on the clutch, releasing the engine, it will stall. In other words, the car will not push start when cold, as if I have no gas or spark. But if I use the key at this point, it will start and idle perfectly, but still get the "regular" stumbling on acceleration as usual. Here's what I did so far in the past 2 years: NEW: oem spark plugs, 2 o2 sensors (california car), new pre-cat, 2nd cat is clean (light shines right through), fuel filter, fuel regulator, air filter, clutch, pcv valve, oil changes (of course), timing belt, battery, alternator, exchanged pcm from an identical car with 50k miles (same exact problem, no change after swapping pcms), removed and cleaned intake manifold, removed and cleaned throttle body and idle air control valve, removed and cleaned EGR valve and fully cleaned the exhaust and intake channels that run to it. (EGR channel runs through the head to the 3rd cylinder exhaust port, this was 95% plugged 1 year ago, it was scrubbed clean through and through), coolant temp sensor, air temp sensor, distibutor/coil, throttle position sensor, compression tested all within 5psi of each other @ 170, fuel pressure tested fine (forgot value, but it was the right amount at cold idle, I didn't check when the stumbling occurs though), new crank position sensor, fixed the common problem of worn crankshaft sprocket for timing belt by wedging feeler gauge pieces in the keyways to reorient proper TDC (got much more power and 4mpg after doing this, but still had same stumbling problem when cold). I am at my wit's end. please help. the car gets 35 mpg around town but is dangerous when getting out of work's parking into oncoming traffic. I occasionally get oil fouled spark plugs (not always, not sure why) , and when I am running a tank with bg44k, the problem doesn't seem to happen as much but is still there. I tested for vacuum leaks using a propane torch all over the entire intake area, there are no air leaks. I sent all 4 fuel injectors to witchhunter.com for cleaning and testing, seemed to help for a week, then happened again. I often shut off the car and coast down long hills in neutral when travelling and it never has a problem pop-starting when warm, it's only when cold when there's a problem as detailed above. I am leaning towards oil leaking down intake valve guides and sticking to intake valves and will be getting an oil catch for the pcv valve this week, but I am not optimistic.
Aug 5, 2008 at 2:48 AM
2CARPRO JACK
  • 11,533 POSTS
Does this vehicle have a Mass Airflow Meter? If so try using a designated cleaner to see if it makes a difference int heway it runs. I havent had much luck with the cleaner as a fix, but if it makes a difference you may be onto something. Sounds like you have already tested/replaced all the usual suspects
Aug 6, 2008 at 12:48 AM
FRANKMIRAGEMAN
  • 10 POSTS
forgot that is what it is called. in the question I posted, I stated that it never had a intake air control thing, meaning no mass airflow sensor. any other ideas on what I should do?
Aug 6, 2008 at 1:32 AM
2CARPRO JACK
  • 11,533 POSTS
Has it ever set any codes?
Aug 6, 2008 at 3:05 AM
FRANKMIRAGEMAN
  • 10 POSTS
no it never set any codes the only hint I have is the use of bg44k helps for a couple of days only. other hint I have is when I gutted the pre-cat 2 years ago it didn't happen anymore, but I lost milage and ran too rich, too much soot on the sparkplugs, so I got another precat and came back to the same problem.
Aug 6, 2008 at 12:05 PM
2CARPRO JACK
  • 11,533 POSTS
Have you checked the MAP sensor? The best thing would to get this thing on a scanner to watch the engine management when cold to see what isnt in range.
Aug 7, 2008 at 12:47 AM
FRANKMIRAGEMAN
  • 10 POSTS
not sure how to check map sensor, someone once told me either a map sensor works or it doesn't, I remember disconnecting it and the car not working at all. I only cleaned the hose and connectors to it, unnecessarily I might add. when I checked all sensor values cold, nothing seemed out of the ordinary, but I don't know what proper manifold absolute pressures I should have when the car is off or idling or on the gas or hot or cold.....
Aug 7, 2008 at 3:05 AM
2CARPRO JACK
  • 11,533 POSTS
It reads vacuum signal... tap intot eh hose with avacuum gauge to see what it is getting for signal when cold
Aug 7, 2008 at 4:16 AM
