2000 Other Mitsubishi Models
2000 MITSUBISHI
BUSTEDUP1
Engine Mechanical problem
2000 Other Mitsubishi Models 4 cyl Two Wheel Drive Manual
Colt 2.4i 16 valve. Head gasket blew. Replaced and pressure tested head ( cold and warm ). Haed is fine. Put head onto block and started up. Water and steam now comes from exhaust. What is the problem?
Aug 18, 2008 at 2:47 AM
  • 110,248 POSTS
Hi:
If the head was good, either you have a cracked block, the head gasket wasn't properly installed, or the head or block is warped.
Mar 9, 2009 at 8:15 AM
