1997 Other Mitsubishi Models Brake and battery light
1997 MITSUBISHI
56,000 MILES • 4 CYL • 2WD • AUTOMATIC
ARTHURL
My Mirage would die on me whenever I stopped. I took out the alternator and it was bad (7.4V). I also replaced the Battery because it had tested bad as well. Now when I drive my battery light and hand brake light flicker on and off. It does not stay lite but as I drive they light up and then go out if I accelerate more or touch the brake.
May 9, 2008 at 11:06 AM
MASTERTECHTIM
  • 4,750 POSTS
these lights coming on together indicate problem in alternator voltage regulator. double check the wiring to the alternator and make sure you didnt leave a plug loose or the feed wire a little loose, also check the tension on the belt. is there a loud squeel when running from the belt area?
May 9, 2008 at 11:26 AM
