1995 Other Mitsubishi Models Temperature Gauge
1995 MITSUBISHI
137,400 MILES • 4 CYL • 2WD • MANUAL
ADAWUDI
I recently flushed my radiator and changed the thermostat. Now the temperature gauge is reading higher. It moves up to about 3/4, and falls back down to the half mark and stays there. The engine doesn't seem to be terribly hot. What could this be?
Jun 29, 2008 at 3:20 AM
KHLOW2008
  • 41,814 POSTS
Hi adawudi,
Most probably you have not bled the system of air properly.
Check radiator coolant level when cold, top up if necessary.
Jun 29, 2008 at 4:19 AM
