1995 Other Mitsubishi Models nocking on injegters
1995 MITSUBISHI
16,000 MILES • 4 CYL • AWD • AUTOMATIC
SHEFF0790
the pejaro is nocking at slow speed but when i go faster the nocking goses the car is ok
Apr 13, 2008 at 9:29 AM
GUS540I
  • 11 POSTS
when was the last time you changed your oil? Get a gauge and check oil pressure, if good and the sound comes from the top of the engine, (i.e. lifter noise), change your oil and add a can of BG "MOA", or a can of "Sea Foam" to loosen up and clear out the lifter oil gallies. If it sounds like its coming from the block of the engine, have it checked out, you may have a bearing going south
Apr 24, 2008 at 9:41 AM
