1995 Other Mitsubishi Models mitsubishi colt
1995 MITSUBISHI
MAC2
Electrical problem
1995 Other Mitsubishi Models 4 cyl Two Wheel Drive Manual
bought a 1995 mitsubishi cot 1.3 gli. drove it home 60 miles over mountain roads and it drove perfectly. fitted a stereo in the car same day and in the process blew the fuse serving the clock and interior light. replaced it and all worked fine. then on starting the car up, the fuel pump makes a very noticable hum and the car will only go a few hundred yards and then the engine dies. it will restart imediately and idle but will not accept throttle without dying. i am getting an erroneous reading from the throttle position sensor. any ideas. also, is it possible that the fuel pump relay has been damaged. many thanks for any help at all.david.
May 5, 2008 at 10:03 AM
  • 31,937 POSTS
Hi there,
First thing to do is check for any fault codes, see if the TPI is acting up. do this first.
Mark (mhpautos)
May 5, 2008 at 6:39 PM
