1995 Other Mitsubishi Models
1995 MITSUBISHI
FRACKFERRETPAWS
Noises problem
1995 Other Mitsubishi Models 6 cyl Manual
I left my car for three weeks while I was on vacation. On returning, I started the car and I hear a consistent tapping noise coming from the engine. The frequency increases and decreases with acceleration and deceleration. The volume stays the same. I noticed that it was about a 1/2 quart below the lower "add oil" mark on the dipstick and I added a quart of oil which brought the level to about halfway between the minimum and maximum marks on the dipstick. Also, could this be a gas brand problem? I always use premium grade in my car no matter where I fill it up.
Jul 31, 2008 at 3:05 PM
  • 31,937 POSTS
Hi there,
You sound as if you have a faulty lash adjuster, try doing an engine service and add a good quality oil flush first,
Mark (mhpautos)
Jul 31, 2008 at 9:36 PM
FRACKFERRETPAWS
Thanks for your answer. I am a woman who has little knowledge re: cars, but I love my 3000GT. I'll have my dad do the oil change you recommended, but I guess I'll have to take it in to Mitsubishi to have them do the engine service. Does a lash adjuster have something to do with the valves? When I take it in I want to appear like I have an idea of what the problem may be.
Aug 1, 2008 at 3:20 AM
  • 31,937 POSTS
Hi there,
Yes that is correct, the lash adjuster sits on top of the valve and controllers the clearance between the valve & the cam lobe,if it fails, there is too much clearance and you get that tick sound.
Mark (mhpautos)
Aug 1, 2008 at 1:55 PM
