1994 Other Mitsubishi Models won't start timing belt or what
1994 MITSUBISHI
127,000 MILES • 6 CYL • 2WD • AUTOMATIC
ICEMAN27
i just installed rebuilt heads and this is what i get. I checked for fire and gas they both were fine.Checked compression No.1 & 2 80psi No.4 110psi, No.3 & 5 150psi, and No.6 80psi.Does this mean the timing is off or should i retorqe the heads.Or is it the block? Somebody please help!
Apr 7, 2008 at 2:27 PM
GUS540I
  • 11 POSTS
I assume the heads were rebuilt by a reliable shop and you checked the rings before re installing the heads. If yes to both I'd assume your valve timing is off. Rotate the engine until the Top Dead Center marks are where they are supposed to be and if you are off even a tooth or two, (i.e. the markers are close but not dead nuts on), your compression readings will be all over the board. A good idea is to rotate the engine by hand a couple of complete revolutions and re align the timing marks before re installing the timing gear components just to make sure you are on the money valve timing wise
Apr 24, 2008 at 12:49 AM
