1994 Other Mitsubishi Models lights
1994 MITSUBISHI
PAULAJEAN
Electrical problem
1994 Other Mitsubishi Models 4 cyl Wheel Drive Type unknown Manual 75000 miles
im having a problem with the lights. the parking lights will not turn off and the headlights will not turn on. the highbeams will work only when using the flash mode but not when i set them them to stay on.
i hope you can help!
Feb 21, 2008 at 10:41 PM
2CARPRO JACK
  • 11,533 POSTS
without knowing what kind of Mitsu you have, I would venture a guess to be the headlight switch, that is where all of those things meet
Feb 21, 2008 at 11:40 PM
MERLIN2021
  • 17,250 POSTS
Hard to look up "other models" but check the multifuntion switch on the column...and what happens if you pull the fuse for the lights?
Feb 21, 2008 at 11:41 PM
