1993 Other Mitsubishi Models Clutch
1993 MITSUBISHI
150,000 MILES • 6 CYL • AWD • MANUAL
HARVEY FISHER
I just had a new engine put in and after driving it about an hour the clutch failed. It goes to the floor REAL easy and won't shift. I know they took the transmission out to put the engine in. Is there something that they could have put back in wrong. They said the clutch parts all look new. Also, is it something I can fix myself?
Feb 2, 2008 at 2:03 AM
MASTERTECHTIM
  • 4,750 POSTS
check the level of the fluid in the clutch master cylinder, if ok have the guy who put in the engine look at it, he should be able to find the problem in minutes, it can only be clutch master or slave cylinder. hope this helps
Feb 2, 2008 at 2:10 AM
