1993 Other Mitsubishi Models Car jerks sometimes
1993 MITSUBISHI
125,000 MILES • 4 CYL • FWD • MANUAL
MRINALR
The cars is good, but sometimes it jerks while i am crusing. It usually happens when i rev up a bit, but the problem is not replicable. Its like the engine doesnt get any power or fuel and then suddenly it does. Usually such things happen when you are trying to learn a manual car. Put it in the first gear and if you dont let go of the clutch properly it jerks right. The same but while cruising. I went to firestone for engine diagnostics and they couldnt replicate the problem, but they did say that i have a different air filter installed. Any suggestions?
Earlier i thought maybe some problem with the fuel.
Can there be a problem with the transmission?
Aug 20, 2008 at 4:09 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
To come and go like that could be ignition. When was it tuned up last? OEM parts? could be a bad plug wire or plug that acts up under load, fuel filter been replaced? without anything solid to go on, it will be starting basic
Aug 21, 2008 at 8:14 AM
