I was trying to diagnose why my license plate lamps would not work. In the process, I put a wire across 2 of the contacts on my head lamp relay located in the engine compartment fuse box.
In the process, I blew some type of fuse. Now, the headlamps and marker lights won't come on. Also, the dashboard instrument light that usually comes on when the headlight switch is turned on is out.
The high beams work temporarily if I pull the flash lever backwards. The signal lights work. Everything else is functional on the car except the external lights are all hosed.
Please give me a clue what I may have done. Thanks.
Jun 4, 2008 at 2:22 AM
