Transmission problem
1992 Other Mitsubishi Models 6 cyl All Wheel Drive Manual
hI, i HAVE A 1992 3000GT VR4 AND WAS NOT USED FOR ABOUT 6 MONTHS. i HAVE A PROBLEM WITH THE CLUTCH THAT DOES NOT HAVE PRESSURE. TRIED TO BLEED THE LINES IN THE CLUTCH RELEASE CYLINDER BUT NO OIL COMES OUT THE BLEED VALVE. DISCONNECTED THE LINES AND THEY ARE NOT CLOGGED CHECKED THE BOOSTER AND IT WORKS GREAT ACCORDING TO THE TESTS IN THE MANUAL. THE CLTCH RELEASE CYLINDER HAS NO PRESSURE AND THERE IS NO OIL LEAK. IS THE PROBLEM THE MASTERCYLINDER OR THE RELEASE CYLINDER OR ANY OTHER THING?
Jun 17, 2008 at 7:53 PM
