1990 Other Mitsubishi Models
1990 MITSUBISHI
163,225 MILES • 4 CYL • FWD • MANUAL
VERNON07
hi ive got a 1990 mitsi fabio 4spd manual my problem is the clucth when its in gear it doesnt move the clucth foot pedal is still tight do you think its the pressure plate is bugged or is there a slave clyinder for it cause i was driving sweet as then it just wouldnt move your help will be greatly appericated cheers
Jun 25, 2008 at 2:43 PM
KHLOW2008
  • 41,812 POSTS
Hi vernon07,
If you can shift into gear with the clutch pedal depressed, it is not the hydraulic or cable syatem.
If releasing the clutch pedal and the car don't move in any gear, the clutch disc has worn off.
Jun 28, 2008 at 4:01 PM
