ignition timing? 1989 MITSUBISHI GALANT
1989 MITSUBISHI
1,000 MILES • 4 CYL • FWD • MANUAL
CHACIP
I loose the timing because i pulled out the distributor assembly then i pulled the cylinder head and the cam shaft. the reason is, the spark plug got broken cut into 2 piece. is it possible to show me the diagram for this. they told me it's a cyclone engine
Dec 6, 2007 at 8:07 PM
JWALTH02
  • 180 POSTS
Here is how to install the ignition distributor and how to set the ignition timing. Check out the images (below). Let us know if you need anything else.
Dec 6, 2007 at 8:25 PM
