1988 Other Mitsubishi Models Need help in trying to determin
1988 MITSUBISHI
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
COMAR27
I was driving my 1988 Mitsubishi Van when i suddenly started to hear faint clicking noises coming from the engine just as i exited the freeway to find out what was causing it stalled and smoke started coming out from the engine compartment. I soon found out that the smoke was the result of oily greenish liquid splattered all over the hot motor and dripping away at the bottom--before any of this my engine oil light came on about a day ago and i had managed to pour a quart in there -then continued to drive it again...until this happened. I think it could be a water pump or hose issue but im not sure until i know what else to look for, please give me some advice...
Dec 22, 2007 at 6:14 PM
  • 31,937 POSTS
Hi there,
You will have to get the system pressure tested to determine all the leaks. Don't second guess as it may prove to be very expensive repair if you do a head gasket, Get the coolant filled and get to a work shop before you do some real damage, Hopefully you can get it fixed before a disaster strikes.
Mark (mhpautos)
Dec 23, 2007 at 12:11 PM
