02 Mitsubishi Diamante
2002 MITSUBISHI
MREECE83
I have an 02 Mitsubishi Diamante VRX. The car will crank, start and go dead all within a matter of seconds. It will do this several times and then will crank but not start. After continuing to start the car for 5 or 10 minutes, it will then start and will stay running until turned off. What could be the problem?
Apr 25, 2007 at 11:37 AM
  • 75,988 POSTS
[quote:3084d41f8b="MReece83"]I have an 02 Mitsubishi Diamante VRX. The car will crank, start and go dead all within a matter of seconds. It will do this several times and then will crank but not start. After continuing to start the car for 5 or 10 minutes, it will then start and will stay running until turned off. What could be the problem?[/quote:3084d41f8b]
Check the fuel pressure,Could be the fuel pump relay or the pump itself
Apr 25, 2007 at 1:26 PM
