2006 Mitsubishi Montero jerking during acceleration
2006 MITSUBISHI MONTERO
SCOTT82
2006 Mitsubishi Montero Automatic
while accelerating vehicle will start jerking as if transmission cant decide whichgear to select
Oct 18, 2010 at 3:57 AM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 18, 2010 at 12:20 PM
