2003 Mitsubishi Montero miss fire
191,000 MILES • 6 CYL • 4WD • AUTOMATIC
MONTERO2003
first the engine has a clicking noise from the lifter top cylinder later the scaner read cylinder 3 miss fire there was some oil on the plugs they change the camshaft lifters and some seals it work only for one day the sound is there and the oil is on the plugs again the scan says cylinder 3 miss fire
Apr 29, 2010 at 1:54 AM
  • 75,988 POSTS
Check the compression on no.3 to determine if its valve or ring problem.
Apr 29, 2010 at 5:32 AM
