2003 Mitsubishi Montero dash lights
2003 MITSUBISHI MONTERO
108,000 MILES • 6 CYL • 4WD • AUTOMATIC
GIFFORD
My indicator lights the ones that shows if you are in 4 weel drive or 2 wheel drive blinks the yellow/orange light in the center while I am drivine after about 20 miles. I had the therm. replaced and the transmission fluid replaced. This kept the light off for about 1 month when it did this before. It does not seem to be driving any different, just like a car with 100000 miles. Any help will be great. Also if i turn the car off the light will go off for about another 20 miles
Feb 2, 2009 at 3:09 PM
ACV
[quote:6545f1e214="gifford"]Engine Mechanical problem
2003 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic 108000 miles
My indicator lights the ones that shows if you are in 4 weel drive or 2 wheel drive blinks the yellow/orange light in the center while I am drivine after about 20 miles. I had the therm. replaced and the transmission fluid replaced. This kept the light off for about 1 month when it did this before. It does not seem to be driving any different, just like a car with 100000 miles. Any help will be great. Also if i turn the car off the light will go off for about another 20 miles[/quote:6545f1e214]
I have a similar problem that just started with my 2003 Montero. I have 128k miles. Did you find a solution or determine what the problems is. Mine drives fine as well.
Mar 2, 2009 at 10:51 AM
KJEFFERSON
havin gsame issue on my 2003 as well, apprx 109000 miles
did you find out the cause of this
Sep 24, 2009 at 8:10 AM
