2003 Mitsubishi Montero
2003 MITSUBISHI MONTERO
36,000 MILES • 6 CYL • 4WD • MANUAL
NLZONE
I have a 2003 Pajero/Montero, it has manual transmission.
I've noticed that whenever I put it into gear to start off, as I let go of the clutch I get a slight bump, same thing when I shift into 2nd, 3rd or sometimes even on 4th gear. But if I slowly let out the clutch and give it more gas I don't feel the bump much or sometimes there's nothing. What could be the problem? is it the transmission or the rear differential?
thank you.
May 16, 2008 at 6:17 PM
  • 31,937 POSTS
Hi there,
your description of the "bump is a bit hard to imagine... so i will suggest you start my checking the drive haft uni's first also foe a loose flange on the transmission or diff. start here.
mark (mhpautos)
May 16, 2008 at 9:09 PM
NLZONE
Hi Mark,
I will do the checks later on this week, thanks for the advice, will let you know how it turns out.
Nlzone
May 18, 2008 at 8:54 PM
