2002 Mitsubishi Montero wheel hub assembly rear removal
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
FNNUKE
How do I remove the rear wheel hub assembly? I see four bolts that need to be removed but I can't get a wrench on them because of there is a toothed gear (I think it part of an indicator of ABS) in the way.
Do have have to take the axil or something else apart? Is there a special tool?
Jan 8, 2010 at 12:25 AM
KHLOW2008
  • 41,812 POSTS
Hi fnnuke,
Thank you for the donation.
Is this a disc or drum brake system?
Jan 10, 2010 at 12:39 AM
