2002 Mitsubishi Montero Water leak on passenger side
2002 MITSUBISHI MONTERO
14,900 MILES • 6 CYL • 4WD • AUTOMATIC
MECASTANON
my vehicle is leaking water on the passenger side, under dashboard. can a drain valve be clogged, if so, how can I access it to drain the valve.?
Sep 29, 2009 at 12:30 PM
BMRFIXIT
  • 19,053 POSTS
AC condensation
drain is on the outside on the fire wall
Sep 29, 2009 at 12:56 PM
SPECTRE1
You said the drain is outside the firewall......Just where is the drain on a 02 Montero XLS? I've been working cars for 38 years and can find no drain outside the firewall on this vehicle.
Oct 4, 2009 at 11:02 AM
BMRFIXIT
  • 19,053 POSTS
AC condensation has to drain
out
place it on lift and check passenger side on the out side of the fire wall under the HVAC box
Oct 4, 2009 at 11:06 AM
