2002 Mitsubishi Montero Torque Converter
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
BUBBLZ
My friend has pulled my motor out of my Montero Sport. We are now having extreme difficulty with socket size to remove the torque converter. They are thinking they need a 16 1/2 socket because the 16 is to small and the 17 is to big? Can you help? Is this true? Where do I get such a thing?
Thanks, Michelle
Jan 13, 2008 at 8:23 AM
BLACKOP555
  • 10,386 POSTS
you may need to try a standard set, if you can turn it 1/16 of and inch each way then the socket is too bog.
Jan 13, 2008 at 10:34 AM
