2002 Mitsubishi Montero running on 4 cylinders
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOWNALI
Not firing off 3 and 6 , changed coil so that's not the problem. Other 4 plugs are firing except those 2...help please!
Feb 24, 2010 at 1:14 AM
DOCFIXIT
  • 18,828 POSTS
You mean no spark from coil to plugs?
Feb 24, 2010 at 1:20 AM
BOWNALI
no fire from spark plugs to the coil, when you unplug the spark plug wires from the coil from the other 4 they are firing off, #'s 3&6 are not firing off when they get unplugged
Feb 24, 2010 at 3:02 AM
DOCFIXIT
  • 18,828 POSTS
Check for voltage on Black/white wire to coil if power put test light on Brown/red wire engine running does test light flash?
Feb 24, 2010 at 7:48 AM
