2002 Mitsubishi Montero fan motor
2002 MITSUBISHI MONTERO
171,000 MILES • 6 CYL • 2WD • AUTOMATIC
BELCHERP
Usually, not always, whe I turn the fan on for the air, there is a high-pitched squealing. When I turn the fan off, it quits. If I turn it on and it does n ot squeal, the air is cold. If I turn it on and it squeals, the air blows warm.
Jun 17, 2010 at 8:21 AM
Check if the AC belt is loose if ok could be the compressor is locking up, sooner or later the AC belt will break
Jun 17, 2010 at 8:37 AM
