2002 Mitsubishi Montero Engine missing when cold started
100,239 MILES • 6 CYL • AWD • AUTOMATIC
TAS01
The engine revs, misses, cuts out at start and initial idle when started cold......seems to be more severe, the colder it is. Once the engine reaches normal operating temperature......it runs fine....
Dec 14, 2009 at 12:33 AM
1515THRIVE
worn spark plugs can misfire when cold. The plugs on a Montero are hard to access, thus, they may be original. Try pulling the easiest to get to and check if it's gapped out.
Oct 6, 2010 at 2:54 PM
