2002 Mitsubishi Montero
2002 MITSUBISHI MONTERO
86,000 MILES • 6 CYL • 4WD • AUTOMATIC
PGMREED
The car temp gage jumps all over we have changed the thermostat flushed the radiator both sending units and heater control valve the gage still jumps all over will peak up to the H but come down very quick have touched the top of the radiator and both hoses and not real hot also the radiator is not bubbly over or into the resorvior I have run out of ideas any chance it could be just a bad gage
Oct 14, 2009 at 3:36 PM
PGMREED
[quote:4fed2869d2="pgmreed"]Engine Cooling problem
2002 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic 86000 miles
The car temp gage jumps all over we have changed the thermostat flushed the radiator both sending units and heater control valve the gage still jumps all over will peak up to the H but come down very quick have touched the top of the radiator and both hoses and not real hot also the radiator is not bubbly over or into the resorvior I have run out of ideas any chance it could be just a bad gage[/quote:4fed2869d2]
Oct 14, 2009 at 3:38 PM
