2001 Mitsubishi Montero Too many amps
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
BCH66
Recently I noticed my left rear break & tail lights were not working; easy fix right, wrong. It was not a burnt out bulb, but I believe I am pushing too many amps though that particular circuit.
Initiallly I replaced the 10 amp fuse and it blew...bad fuse I tought, 3 fuses later I change my mind. I was curious and even put a 15 amp fuse in the fuse slot and it blew as well.
I checked for loos connections, but could not see any. At this point I am stumped, do you have any suggestions as to what the problem might be?
Feb 21, 2008 at 4:14 PM
MERLIN2021
  • 17,250 POSTS
Somewhere between the switch at the brake pedal, and the bulb in the back, the power wire has come into contact with a ground, this is known as a short circuit. You will have to trace the wire....
Feb 22, 2008 at 12:26 AM
