HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Montero
Engine
Symptoms
Overheat
2001 Mitsubishi Montero overheating
PREDRAG
MEMBER
2001 MITSUBISHI MONTERO
6 CYL
4WD
AUTOMATIC
90,000 MILES
Temp. Guage show overheating but engine has normal temp.I have replace temp. Sensor, termostat. Mitsubishi Montero 2001 Limited. Thanks
Pete!
Tuesday, March 10th, 2009 AT 4:14 PM
DOUGL3NC
MEMBER
The problem you have is quite common to NM model Montero/Pajero's.
Your temp guage in the instrument cluster is faulty and will need to be repaired. Check with your dealer on replacing the guage
Thursday, April 30th, 2009 AT 9:51 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Engine Overheats
Engine Cooling Problem 6 Cyl Four Wheel Drive Automatic 105000 Miles Hi, I Have A 2001 Mitsubishi Montero Ltd With A 3.5 Engine....
Asked by
mikesLTD2001
2001
MITSUBISHI MONTERO
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
2001 Mitsubishi Montero Over Heating
2001 Montero Starting Over Heating. I Replaced The Thermostat But Got Same Result. I Removed The Thermostat And It Quit Running Hot For A...
Asked by
eddie fortner
2001
MITSUBISHI MONTERO
2001 Mitsubishi Montero Over Heating Smells Like...
I Had A Problem With My 2001 Mitsubishi Over Heating And Had The Radiator Flushed And Cleaned. The Temp. Gage Does Not Go Past ½ Way But...
Asked by
butchrgv
2001
MITSUBISHI MONTERO
My 2001 Montero Still Over Heats After I Changed The Fan Clutch, Thermostat And The Heat Sensor. While I Am Driving The Temp Gage Will Move...
Asked by
butchrgv
2001
MITSUBISHI MONTERO
Overheating
Hi, I Am Having Issues With My 2001 Mitsubishi Montero Sport 3.0. It Keeps Overheating And I Cant Seem To Find The Solution. I Have...
Asked by
dandancan
1 ANSWER
2001
MITSUBISHI MONTERO
VIEW MORE
Coolant Leak Symptoms
