2001 Mitsubishi Montero Engine Vibration
35,000 MILES • 6 CYL • 4WD • AUTOMATIC
PRESTONS
Dear Sir / Madam
I own a Mitsubishi Pajero 3.5 liter V6 GDI and have the following problems can you help?
1. The engine vibrates at around 2000rpm; above and below this figure the engine is quite smooth
2. If I take off with full throttle from a standing start the engine remains in 1st gear and labors at the high end revs
Thank you
Paul
Nov 5, 2008 at 3:51 PM
KHLOW2008
  • 41,812 POSTS
Hi prestons,
Thank you for the donation.
I suspect the problem of vibrations at 2000 rpm to be from the EGR. As to the labouring at high rpms, there are many possibilities. Eg are TPS out of sdjustmenr, timing belt out of sync.
Has the Check Engine Lamp ever showed while driving? For Mitshubishi sometimes the CEL does not show but error codes are stored in the ECM/PCM. Get a diagnostic scan to find if there are any Data freeze frames. If any found, please let me know the exact code to enable me to get the correct info.
Was any repairs or parts replacement done on the vehicle recently or prior to the above happening?
Nov 5, 2008 at 9:48 PM
PRESTONS
What is the EGR and where is it located so I can advise the mechanic,
> No
I will try to arrange a diagnostic scan and will advise you of any codes.
>No
Many Thanks
Nov 6, 2008 at 12:03 AM
KHLOW2008
  • 41,812 POSTS
Hi prestons,
The EGR valve is located on the intake manifold. You need to check the system, not just the valve.
Nov 6, 2008 at 2:19 AM
