2001 Mitsubishi Montero Caliper Bolt Threads
2001 MITSUBISHI MONTERO
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
KLBJ2007
I am trying to replace my brake pads on the front. I am having trouble breaking loose the bolts holding on the calipers. Are the threads on these bolts standard or reversed?
Mar 3, 2008 at 7:14 AM
BLACKOP555
  • 10,386 POSTS
try using a torch and heating hte bolts up untill they are cherry red then try turning them out, be sure to use a 6 point socket or wrench with a long bar attached to the end for leverage, they should be regular standard threads.
Mar 3, 2008 at 10:54 AM
