2000 Mitsubishi Montero turn signals inside and outside not
110,000 MILES • 6 CYL • AWD • AUTOMATIC
VICI102854
all of my inside and outside turn signals quit working.
all of the rest of the inside and outside lights work.
i checked the fuse and it is ok. i found a flasher and it seems to work the hazard lites. i don't know if there is another flasher for the turn signals. could it be the turn signal switch on the steering column?
Help! i can't afford to go to a mechanic.
thanks
May 3, 2010 at 8:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the turn signal and hazard flasher is one unit behind the left side of the dash. if it's OK and the bulbs and fuses are OK as well then the most likely fault is the signal switch
May 3, 2010 at 8:59 AM
