2000 Mitsubishi Montero Turn signal.....
2000 MITSUBISHI MONTERO
142,300 MILES • 6 CYL • 2WD • AUTOMATIC
FABRICGATOR
Please explain the best approach to access the RH front turn signal bulb. It seems to be obscured inside the fender. The way I see it, either I pull a few inner fender panels and reach inside, or I remove the light assy to get to it. Please advise... Thank You for your anticipated reply.
May 19, 2009 at 1:52 AM
  • 110,194 POSTS
You should be able to remove the light assembly to access the bulb. Can you find the mounting locations?
May 19, 2009 at 8:29 AM
FABRICGATOR
No I can't find all of them. I have removed the few obvious ones but there seem to be a few more. It seems like a bit of work when it used to be so easy.
Can you pull up a picture from your manuals database?
May 27, 2009 at 4:37 PM
  • 110,194 POSTS
I am unable to cut and paste pictures from there. Is there anything in the owner's manual about replacing this light?
May 28, 2009 at 12:07 AM
