2000 Mitsubishi Montero smoke
2000 MITSUBISHI MONTERO
155,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANGELLL
Hi, I recently bought a Montero Sport 2000 but, when it sits on traffic with the motor on, after a good half and hour, if accelerate starts to release white smoke, I am not sure if it is the rings around the pistons or something less expensive, the motor does not make any noises or leaks oil or any other fluids, if you could help me I would appreciate it. Thank you.
Jul 27, 2008 at 1:43 AM
MERLIN2021
  • 17,250 POSTS
White smoke is usually anti freeze burning in the cylinders, have a block test done to see if hydrocarbons are in the antifreeze, and a compression test on the engine.
Jul 27, 2008 at 7:34 AM
