2000 Mitsubishi Montero Shakes when braking
2000 MITSUBISHI MONTERO
51,000 MILES • 6 CYL • 2WD • AUTOMATIC
WOMBATS1975
My Montero sport shakes at high speed braking maybe 55 mph and above. also the stering wheel shakes a little when i drive straight.. I have new tires, balanced, front end alignment recently done, new brake pads, and new rotors.. what else am i missing.. thanks, eric
Oct 10, 2008 at 7:07 AM
DOCFIXIT
  • 18,828 POSTS
Check tie rods any play will caues wobble
Oct 11, 2008 at 7:54 AM
TECHNOPRO
  • 45 POSTS
You could ask your tyre people to balance the wheels on the car itself then the balncing will take in consideration any small imperfection from the hub unit as well.
Cheers
Oct 26, 2008 at 11:07 PM
