2000 Mitsubishi Montero code P1400
2000 MITSUBISHI MONTERO
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVEMIT
The engine light is on. Code is P1400. What does Manifold Differential Pressure Sensor Circuit. Is that something easy to change with a new part or does it take an experienced mechanic
Apr 1, 2010 at 5:30 AM
DOCFIXIT
  • 18,828 POSTS
MDP sensor located on top left rear of intake manifold. Replacement not to bad problem is without further testing to confirm would be a shot in the dark.
Apr 1, 2010 at 6:30 AM
