1999 Mitsubishi Montero What hapend when i installed my alt
1999 MITSUBISHI MONTERO
LEVI WILSON
  • 5 POSTS
Electrical problem
1999 Mitsubishi Montero 6 cyl Two Wheel Drive Automatic
when i installed my alternator I heard a pop. now i have no dome light no brake lights no radio and when i put the car in drive the N as in neutral is flashing and the check engien light is on. then when i put it in gear its really rough. what is the problem with my car?
Aug 9, 2009 at 2:38 PM
  • 31,937 POSTS
Hi there,
First thing to do is get a scan done to read the set fault codes, you did not flash the electrics by accident did you?
Mark (mhpautos)
Aug 9, 2009 at 2:40 PM
LEVI WILSON
  • 5 POSTS
can u show me how to rout the drive belt
Aug 9, 2009 at 2:42 PM
LEVI WILSON
  • 5 POSTS
I know that I forgot to unhook my battery cabels when i installed the alternator
Aug 9, 2009 at 2:45 PM
LEVI WILSON
  • 5 POSTS
Please help.
Aug 9, 2009 at 2:47 PM
LEVI WILSON
  • 5 POSTS
i dont have the money im just trying to get my car fixed.
Aug 9, 2009 at 2:48 PM
  • 31,937 POSTS
I will see if i can find the pic of this and post it.
mark (mhpautos)
Aug 9, 2009 at 2:58 PM
  • 31,937 POSTS
With out the code i cant tell what the problem is, but just first off, check all fuses & fusible links, id dose sound like you may have flashed the electrics, check this first.
mark (mhpautos)
Aug 9, 2009 at 3:01 PM
