1999 Mitsubishi Montero gone through 2 alternators and 3 ba
1999 MITSUBISHI MONTERO
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
SMILESHAM
  • 5 POSTS
What is going on with Mitsubishi's electrical system! I have checked several message boards that express the same problem I am having. I have a 1999 Montero and have had to replace the alternator twice and the battery 3 times. I have read all sort of things that I should do. Unfortunately I am not finding the same advice for this problem. I am hoping that you have heard of these burnt out alternator and battery occurrences. Please tell me what to do.
Thanks you in advance for your help.
Aug 29, 2008 at 8:17 AM
SERVICE WRITER
  • 9,123 POSTS
Is it under charging or overcharging?
I have heard of PCM problems with this situation. Also the brand of alternater can be significant. I would suggest USA, Napa premium orWorld wide on this one.
Aug 29, 2008 at 10:53 PM
SMILESHAM
  • 5 POSTS
How do I know if it is under charging or overcharging?
Also what is PCM?
[quote:9625614a6b="Service Writer"]Is it under charging or overcharging?
I have heard of PCM problems with this situation. Also the brand of alternater can be significant. I would suggest USA, Napa premium orWorld wide on this one.[/quote:9625614a6b]
Aug 31, 2008 at 11:32 PM
SERVICE WRITER
  • 9,123 POSTS
What brand alternater are you using?
Testing an alternater:
https://www.2carpros.com/how_to/how_to_test_alternator.htm
Some parts stores will do this as well.
Sep 1, 2008 at 12:10 AM
SMILESHAM
  • 5 POSTS
It's a Master Quality Premium Remanufactured Alternator
[quote:bc2909a595="Service Writer"]What brand alternater are you using?
Some parts stores will do this as well.[/quote:bc2909a595]
Sep 1, 2008 at 12:42 AM
SERVICE WRITER
  • 9,123 POSTS
IF it's out of spec, take it back and see if you can get one of these: USA, Napa premium orWorld wide .
Sep 1, 2008 at 4:48 AM
SMILESHAM
  • 5 POSTS
The technician says there is a oil leaking into the alternator.
[quote:edbeb4ca5c="Service Writer"]IF it's out of spec, take it back and see if you can get one of these: USA, Napa premium orWorld wide .[/quote:edbeb4ca5c]
Sep 1, 2008 at 5:07 AM
SERVICE WRITER
  • 9,123 POSTS
Well that would certaiinly cause a problem.
Sep 1, 2008 at 11:01 AM
SMILESHAM
  • 5 POSTS
FYI there seems to be an ongoing investigation into the mysterious oil leaks that keep causing alternator failures in Mitsubishi's Monteros. Based on my online research, anyone having this problem should have their mechanic check: camshaft, crankshaft front seals, all connections
are clean and in good condition, earth connections, alternator belt is it too loose, too tight or cracked, air conditioner belt, fuse box located near battery, slipping drive belt (it turns the alternator), and diode.
Also, if your alternator is 10 years old or older it probably just needs replacing.
[quote:b24eed5eed="Service Writer"]Well that would certaiinly cause a problem.[/quote:b24eed5eed]
Sep 1, 2008 at 7:09 PM
