1998 Mitsubishi Montero Vibration at 45 and above
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
FBRS2
I have 1998 Montero Sport with vibration above 45 mph. Have balanced tires and checked for out of round tires. Also checked run out on wheels. Replaced a bad carrier bearing assembly on drive shaft but still vibrates. Vibration does not change with braking or if transmission is shifted into neutral.
Aug 9, 2009 at 8:46 AM
  • 31,937 POSTS
Hi there,
Do you feel this in the steering or body or both and to what degree?
mark (mhpautos)
Aug 9, 2009 at 3:14 PM
FBRS2
It can be felt in the wheel and it does shake the whole car. This one really has me stumped...
It feels like an unbalanced tire since it changes with speed. The frequency of the vibration increases as speed increases.
Driveshaft unbalanced maybe?
Aug 11, 2009 at 1:48 AM
  • 31,937 POSTS
Hi there,
I would be making sure that the wheels, tyres & balance is correct, wheel bearings next, drive shafts basically are trouble free balance wise as if they are bad they will be from installation, i have yet to come across a faulty balanced shaft that has not been first damaged in some way.
mark (mhpautos)
Aug 11, 2009 at 2:03 AM
