1998 Mitsubishi Montero ABS SENSOR
CGUDEL
Electrical problem
1998 Mitsubishi Montero Four Wheel Drive Automatic
My Montero is near 200k miles. My mechanic did a diagnostic check and the diagnosis was an ABS sensor. Where is that located?
Aug 29, 2010 at 4:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
there are 4 ABS speed sensors, one for each wheel and each one is on a bracket at each wheel hub.
Aug 29, 2010 at 5:19 AM
CGUDEL
[quote:59564e6e68="bluelightnin6"]there are 4 ABS speed sensors, one for each wheel and each one is on a bracket at each wheel hub.[/quote:59564e6e68]
do you think that could be the reason why my car won't start does it have anything to do with my battery?
Aug 29, 2010 at 5:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
faulty ABS sensor would have nothing to do with vehicle starting. the ABS light in dash may appear though if the charging system is weak and a weak charging system could definitely cause engine not to start. you need to have the battery and alternator tested if that is the case.
Aug 29, 2010 at 10:35 AM
