1998 Mitsubishi Montero
JKP17
Electrical problem
1998 Mitsubishi Montero 6 cyl Two Wheel Drive Automatic
my a/t battery and brake light stay on and the car dies.
Nov 26, 2008 at 7:56 AM
  • 31,937 POSTS
Hi there,
Check the alternator charge rate, you may have a faulty alternator.
mark (mhpautos)
Nov 26, 2008 at 8:13 AM
JKP17
I have a mulitimeter how do i chech the charge rate. thank you happy thanksgiving
Nov 27, 2008 at 2:44 AM
  • 31,937 POSTS
Hi there,
A basic test is just set the meter on 20V scale, and attach to battery with car running, you want around 14V as a benchmark charging voltage.
Mark (mhpautos)
Nov 27, 2008 at 6:48 AM
JKP17
what does it meen if the volage is lower or higher than that?
Dec 3, 2008 at 5:19 AM
  • 31,937 POSTS
Hi there,
If the voltage is to low the alternator is not working and you are just reading battery voltage, if a lot higher the alternator is working but with a faulty voltage regulator, this is part of that internals of the alternator
Mark(mhpautos)
Dec 3, 2008 at 7:08 AM
