1997 Mitsubishi Montero pinging
211,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAWGBYTE
My engine pings when it is warmed up. My mechanic says I have compression. We found bad spark @ the injector wire. Paid to check plugs & had to replace 1 & replaced the plug wires. Helped for a short time w/min ping. Now getting worse under load or up hills. What do you recomend? I've spent as much as I can right now.
Nov 2, 2010 at 11:16 AM
  • 75,988 POSTS
Check the ignition timing if okay-clean out the EGR valve and see what happens
Nov 2, 2010 at 11:19 AM
DAWGBYTE
Thank you . I'll try cleaning the EGR & get back to you.
Nov 2, 2010 at 11:49 AM
  • 75,988 POSTS
Also check if it has a knock sensor its job is to retard the ignition timing when it senses detonation/pinging/spark knock-
Nov 2, 2010 at 12:34 PM
