1997 Mitsubishi Montero Master CYLINDER BLEED
TEAAREASEAWHY
  • 1997 MITSUBISHI MONTERO
Transmission problem
1997 Mitsubishi Montero 6 cyl Four Wheel Drive Manual 38THOU miles
I have to troubleshoot this myself, and have discovered the cheapest place to start will be to bleed the master cylinder, can you explain how to locate the necessary outlet. And how to accomplish this task
Saturday, October 11th, 2008 AT 3:12 AM
TECHNOPRO
  • 45 POSTS
Is it possible to tell us a little bit more about the problem you are facing?
To bleed the master you have to do an air bleeding operation starting from the farthest wheel from the master.
Friday, October 24th, 2008 AT 4:57 AM
