1996 Mitsubishi Montero Adding thicker oild to the engine
1996 MITSUBISHI MONTERO
19,200 MILES • 6 CYL • 4WD • AUTOMATIC
OZZIEDESIGNS
MEMBER
1 POST
Can the engine be harm if I add thicker motor oil?
Jun 28, 2010 at 6:56 AM
✓Experienced Mechanic
The only thing you're doing is slowing down the oil pump pumping action by making it thick unless its smoking then you can go that route
Jun 28, 2010 at 7:00 AM
