HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Montero
Climate Control
Air Conditioner
Not Working
1996 Mitsubishi Montero A/C. Can the belt be removed
JAMES974A
MEMBER
1996 MITSUBISHI MONTERO
Air Conditioning problem
1996 Mitsubishi Montero 6 cyl Four Wheel Drive 107500 miles
Can I remove the belt for the A/C and leave off util I can afford to repair
Monday, June 23rd, 2008 AT 1:46 PM
KHLOW2008
MECHANIC
Hi james974a,
Yes, that would be better than keeping it on since it is not doing any other job.
But when you repair the AC, make sure you remove the rust from all three pulleys, if not it would prematurely wear the belt.
Tuesday, June 24th, 2008 AT 2:20 PM
Please
login
or
register
to post a reply.
Related Air Conditioner Not Working Content
Air Conditioner Not Blowing Cold Air
There Was A Leak In One Of The Hose Sometimes Ago, It Was Fixed And The Gas Was Recharged. So It Started Blowing Cold Again, But What I...
Asked by
Abimart26
1 ANSWER
2003
MITSUBISHI MONTERO
VIDEO
Fix an Air Conditioning Not Working Video
Instructional repair video
GUIDE
Like any sub system in today's car a problem and be minor or a little more involved, this guide will help you find the problem and perform repairs. You can be the judge if...
1999 Mitsubishi Montero Ac Stops Working After Runing...
Hello, When I Turn The Car On The Ac Works Great For About 2 Minutes Then It Begins Throwing Hot Air. I Looked At The Compressor And The...
Asked by
Mauro Madrigal
1 ANSWER
1999
MITSUBISHI MONTERO
2003 Mitsubishi Montero Not Blowing Cool Air
Air Conditioning Problem 2003 Mitsubishi Montero 6 Cyl Automatic 155000 Miles I Had The Belts Replaced And The Air Was Cool For A...
Asked by
Justin1
1 ANSWER
2003
MITSUBISHI MONTERO
1999 Mitsubishi Montero Antifreeze Fumes
I Trying To Understand What Is The Problem And Antifreeze Fumes Go Through The Heating/air Conditioning Vents, Even When Are Shut Off. I...
Asked by
satradukhs
1 ANSWER
1999
MITSUBISHI MONTERO
2005 Mitsubishi Montero A/c Works Intermittently
The A/c Works Intermittently, When I Start In The Morning Its Fine, I Drive To My Office About 10 Miles On A Very Dusty Dirt Road. When...
Asked by
tropix
1 ANSWER
2005
MITSUBISHI MONTERO
VIEW MORE
Air Conditioner - Vacuum Down and Recharge
How to Find Low Side A/C Service Port
