1999 Mitsubishi Montero antifreeze fumes
SATRADUKHS
  • 1999 MITSUBISHI MONTERO
  • 6 CYL
  • 140,000 MILES
I trying to understand what is the problem and antifreeze fumes go through the heating/air conditioning vents, even when are shut off.
I just want to know what to ask the mechanic, so I can fix the problem
Thursday, December 17th, 2009 AT 12:05 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You will need to ask for a cooling system pressure test to be do, this should be done hot & with the heater on, I would say you have a leak in the heater core.
Mark (mhpautos)
Thursday, December 17th, 2009 AT 5:52 PM
